I have a new Encore with catalyst after using an older Encore with catalyst removed for many years. The new stove has a few holes at the bottom on the back wall/refractory which would enter the catalyst area below the catalyst. Then there is the main draft path above the catalyst. I am wondering about what goes through the row of holes? Is this just hot air to preheat the catalyst? Once it is heated, it burns the gases going out the main opening above the holes? Please explain what you know about the flow path. The manual and folks here on the forum recommend pushing the coals back against those holes when building fire and reloading. Is that helping to heat the catalyst? Are the gases burning on top of the hot catalyst or by going through the catalyst after entering holes? Are the holes there to keep catalyst hot for combustion above?
I will be posting a separate question in the temperature thread about the probe for the catalyst temperature.
