Hoping those smarter than me can chime in here. I got to the top of my chimney finally to measure for a new liner and cap. What I found up there surprised me a bit thus the questions.
Currently installed is a 4” liner for a propane insert that is removed (insert) and there were two liners attached to it. Up at the top of the chimney, the cap has one liner attached (pic below). There is a small hole for the other liner but it’s not attached. Is it possible it came loose? Or is the second flue a fresh air intake and all they did was run it partially up the flue?? There are no other exits to the chimney however there is a small opening with a grate outside but it’s below where the two liners pass through the damper. Can’t see the second liner from down the flue (pics attached).
Second question and more a confirmation. The oil furnace vents in it’s own separate flue that is round, approx 5” (pic attached). Why is it not capped as well? Never had an oil furnace like this previously so want to be sure it’s okay like that or not.
Final question is the current cap is attached to a 13”x13” approx clay liner. This cap appears non useable due to it appears to be designed for the 4” flue only. This cap is attached with only “compression” type bolts and my understanding is the new cap should be properly caulked to the clay liner, correct?
My current plan it to order the following, concerns?
Step 1: Select a Pre-Insulated Chimney Liner: 1 x Pre-Insulated Chimney Liner - 6 in. x 35 ft. (SKU: NDBP635-K)
Step 2: Select one stainless steel bottom connector per flue liner selected in step 1.: 1 x 6 inch Standard Tee, 10 in. Snout, and Tee Cap (SKU: NNC6FLEXTL-NC6ECL-K)
Step 3: Choose one stainless steel top plate: 1 x 6x13x13 in. Deluxe Flat Hinged Chimney Cap (SKU: RCDTCM6-88-K)
Left has liner attached with clamp. Right is just a 4” hole and no liner attached to cap.
![IMG_4334.jpeg IMG_4334.jpeg](https://www.hearth.com/talk/data/attachments/315/315916-87075a9015d5be186bf3d0535ebeaefc.jpg)
Oil furnace flue
![IMG_4333.jpeg IMG_4333.jpeg](https://www.hearth.com/talk/data/attachments/315/315918-d3ab0f388d802f78dc08fad5d635a74f.jpg)
![IMG_4346.jpeg IMG_4346.jpeg](https://www.hearth.com/talk/data/attachments/315/315920-9c4452907eda810d15d1f841d56c1289.jpg)
Oil furnace flue
![IMG_4339.jpeg IMG_4339.jpeg](https://www.hearth.com/talk/data/attachments/315/315919-95202278b1d00b977787437e404d9175.jpg)
