chipsoflyin said:Yes, check on top of the baffle
WarmInIowa said:Good idea, did you have help getting it off your truck? I assume it shipped in a crate. I'll find out soon, if it ever gets here. Was scheduled for Friday, but the terminal now says Monday. It's gonna be a cold weekend at my house! I've been sad for two days now with my Fireview taken out of service for the larger hearth install!
sam_j said:That IS a good idea. What diameter are the bolts- 1/2 or 5/8? And what size are the wheels? I'm supposed to be getting a PH in March so I may copy your idea, if you don't mind.
Nice! I might have to make up one of those to make it easy to swap stoves if I want to...3fordasho said:1/2-13 x6" length bolts on one end, use threaded rod on the other end, (otherwise you have to cut the bolts with a sawsall to get the board out from under the stove once it is in place). The wheels are 4" diameter with a 5.5" distance from the floor to the mounting plate of the wheels. I used all swivel wheels for maximum ability to shift position of the stove. The main board under the stove is a 2x12", the cross boards the wheels mount to are 2x6". Seems plenty sturdy to support the stove. I did use a pair of ratchet straps to secure the stove to the 2x12.
sheeplenot said:That dolly you made is pretty cool.My progress will be here in 2 weeks and I was trying to figure out how to move it.I have access to a pallet jack do you think it would work?
Waulie said:The pallet jack I rented was for a standard pallet, but the pallet they use is not standard. The forks of the jack were too wide to fit in the grooves of the pallet. I still ended up using it by placing the one fork of the jack in one groove, jacking the stove up a bit, and blocking under it. Then the same thing on the other side. Then, I slid the forks under the bottom of the pallet. It worked, but not nearly as slick as I'd hoped.
rideau said:Tim- When did they send you the new screen? Is it any different? I last spoke with them about three weeks ago about the screen, and they were working on a way to more positively attach the screen. Don't know whether they have come up with anything yet. My screen came with one side slightly damaged...the screening lower edge of screening is coming apart...so really cannot slide one piece over the other on installation. The first piece goes in fine, second piece I sort of seat and say a prayer. Woodstock advised bending the little tab a bit to get better installation. You might call and ask them about that...it may help yours to stay in place. Maybe they have already bent your replacement differently, though? I'll wait another week, then give them a call re the screen...
rideau said:Tim, I'm not sure they are quite right. Hard to be sure, but it looks like the two screens are abutting, not overlapping? One is supposed to sit inside the other, then you are supposed to slide them apart and they are supposed to overlap..by about 1 inch, I think. Woodstock will e-mail you directions if you give them a call. One of my screens has a line of mesh pulled out at the bottom -came that way- and mine won't slide against each other. SO I had to put one in, which fit fine and sort of snapped into place. Then I could not for the life of me get the other in. SO I sort of propped it where it was supposed to be and called Woodstock to see if that was OK. They told me as long as it stays. It's been there for quite a while now. Checked the screen by flashlight while stove was cold about an hour ago. A few of the squares are full of ash, but just a few and the screen is such a pain that I'm not going to clean it until it gets worse. I figure why ask for trouble? But do check about the screen. I think if its not overlapping it may be more apt to fall...
3fordasho said:So far the new screens are staying in place... that said I'll find them in the firebox when I get home later today ;-)
Besides replacing the screens I applied some hi-temp antisieze to the the rod that acts on the bypass plate, operation had become very noisy and rattled the stove abit.
It's better now, perhaps it was enough to rattle the screens out of place?
