Hello gang,
New to Hearth.com and quite interested in the "Boiler Room" area... I'm in the process of building a new house and winter is quickly setteling in! It's time to choose the means to heating this structure. I have my sites set on an outdoor located boiler, but have no interest in the water surrounded bond fire models
I can appriciate the gasifier models! I was going to build a small stucture to house the boiler not too far from the house put a couple of 200 gal oil tanks as storage in the house basemement for this year until next summer where I will build an outdoor underground bigger tank. My back up heat will be a couple of 60 gal hot water tanks so I want to try to not rely on the electricity as much as possible. I've narrowed my search to eiter HS Tarm or Orlan, the EKO being about $2000 cheaper and the local rep being closer to here, for these reasons I'm leaning towards the Orlan at this time. I'm at the point where I have to choose the size of the boiler. The house is an 1700 sqr foot R-30 through out (ICF foundation and SIP panels walls) with full basement with radiant for heat and forced air hot water air handler for ground floor. There is quite a bit of glass area in the house not too much southern exposure and a cathedral ceiling in the living room. There is an 800 sqr foot garage attached that is insulated to the same R-30 that will be heated by radiant probably not to the full room temp but maintain a comfortable temp. Future would be a 1200 sqr foot work shop heated by radiant to probably 10 ° C except when occupied on weekends where it would be brought up to room temp. I hope to also do domestic hot water and in the summer cool times heat an above ground insulated liner swimming pool to 27 ° C. Given these specs does anybody have any recommendation as to what size Orlan 40 or 60 or HS Tarm 40 or 60. My Goal would be to eventualy go to one fire a day preferably starting the cycle after work and one feeding before heading to bed.
Could some of you owners give me an idea of home sizes being heated, insulation rating or age of home to give idea of heating loads. If your using storage, how big it is and how long you can run on stored heat?
Thanks in advance!
Paul
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Thanks in advance!
Paul
