Hi All,
We are building a small house in Connecticut with a wood stove. We are planning for a Vermont Castings Encore.
The house will have a true brick chimney and a brick firebox "surround" that supports the chimney above and simulates the appearance of a fireplace. The wood stove will be nested inside this brick surround.
Our question is about minimum clearances. I assume that we need to adhere to the minimum NFPA clearances on the attached illustration (even in the case of brick), in order to give the stove ample "breathing" room to dissipate heat. Is this correct? Is it safe to reduce any of these clearances so we can build a smaller "firebox"?
Are there other considerations for this kind of brick surround / wood stove setup? I realize it would be much easier to simply use stovepipe, but the house really calls for a brick chimney and we feel the expense is worthwhile.
Thank you for your thoughts!
![Question about New Construction, VC Encore, Brick Chimney and Firebox Surround Question about New Construction, VC Encore, Brick Chimney and Firebox Surround](https://www.hearth.com/talk/data/attachments/291/291657-0f0d3c4508f335334289ae012aa77863.jpg)
