Hello all, over the years hauling wood has gotten harder, currently using an ATV with a trailer. Hauling large bucked logs to and into the trailer is getting more than I care to do. So I got a logging winch for my tractor. I finally gave it a try today and it was easier on the body but took way longer than just bucking and hauling with the trailer.
I know the basics of how to use the winch (got a demo for a sales guy at the fair) but I bought this one used and no instructions.
What took a long time was hooking and un hooking the logs, Im thinking im doing it wrong. So what I have is this: The cable from the winch has three loose 'chain hooks' ill call them. They can slide along the cable, these hooks have a round hole and a slot to allow feeding the chain through and locking in the slot. On the end of the cable is another hook that is slotted and can either fit a chain link in there or the cable itself.
The 'chokers' as Ive been told they are called are 5-6' chains with a large needle like rod on one end and a red round hook on the other end. I have no idea what either of these end pieces are for.
So the way I used the chains is, I fed the needle end through one of the chain hooks on the cable and hooked the end by the red round hook in the slot. I then wrapped it several times around the log and fed the needle through the chain hook again and locked it in the slot. THe end hook on the cable I just wrapped around the log and slipped the cable in it and just the cable to haul that log with.
So my questions are:
Is it ok to wrap the cable around a log and lock it in the cables end hook and haul just with the cable or do I risk damaging the cable?
On the chain chokers what is the round red hook and the needle on the other end for? IE what is the proper way to connect a log to the cable hook with the choker?
THanks
~ Phil
THanks
~ Phil
