Hi Guys,
Couple questions I was looking for some help with:
High Temp RTV Sealant to Seal Insert to Extension?
I installed a Century CW2900 Wood Insert close to 2 years ago along w/ an insulated chimney liner. Just did my initial burn w/ a creosote log and learned an important lesson. Always do a small burn first to check for leaks. When the creosote log started to smolder, the heat from the fire dissipated enough that there was no longer an adequate updraft creating a wonderful smell in throughout the house. Between my insert and liner, I have an extension to get more of the insert into the room (to hopefully allow more heat transfer into the room). Worked well last year, but this year between the insert and extension there's a leak. Now I know the insert can get really, really hot, so I wasn't sure if the black high temp rtv fireplace sealant could hold up to that kind of heat? Is that what I should use to fix the leak? If not, what is recommended...should I just get rid of the extension and connect the liner directly to the insert. That was my original configuration, but it only allowed about 3" of the insert to protrude into the room, so the heat transfer was diminished.
Fresh Air Intake?
I've got a problem. We have a big house, and even if we've got a roaring fire going, we inevitably always get some smoke in when we restoke the fire. Tried everything I've read on the draft thread, but still have issues. Wasn't sure if maybe a fresh air intake would alleviate some of those issues. It wouldn't be a simple install to get a 2 or 3" pipe into the chimney...not even sure where to begin as a DIYer. But maybe it'd be worth it if it could keep the house from smelling like a campfire?
Keep Less Heat From Escaping?
Here's a picture of my insert.
![Question about Insert Leak, Fresh Air Intake, and Improving Efficiency Question about Insert Leak, Fresh Air Intake, and Improving Efficiency](https://www.hearth.com/talk/data/attachments/232/232430-fc9ad19844b190c95a976ce7b5f06752.jpg)
It has a liner of what I think are 1.25" ceramic bricks. It includes a blower, but doesn't seem to move a ton of air through a shell that surrounds the firebox. There has to be a way to drag more heat out of this thing. It seems like right now, 80% plus goes out the chimney. Is there not a way to improve the heat transfer between the insert and the inside of the house? Maybe some ac coils wrapped on the sides w/ a box fan and small pump to move the water?
Easy Starters?
Right now, I'm using a propane torch to get the fires going. We had the same problem as before...smoke leaking into house. Even w/ adding a heater and opening a door to make sure the house had positive pressure to allow the air to rise in the chimney...we'd still get backdrafts...wind or no wind. I'd really like to add a propane starter, but don't want to do anything dangerous. Are there any aftermarket starters you can add to your insert to make starting a fire easier? I typically use the firestarter sawdust things...which work ok, but an easier starter would just make using the fireplace more convenient.
Fresh Air Intake?
Easy Starters?
