The internal damper, (Item # 8 on this page)
http://www.woodinsert.com/tl200.php
came loose from the frame (item #10) tonight after I loaded the stove and tried to shut the damper. I'm guessing either one of the clips broke or one of the pins on the damper. The gasket on the frame has been missing for a while, which is on the back of the frame, you can see it in this image.
https://cdn6.bigcommerce.com/s-1r4c...4/1645/1-10-08057-3__47891.1493887536.jpg?c=2
Does this look like anything special to you other than just plain gasket material? I figure while I have it apart I might as well replace the gasket. I didn't know if it had to be anything "special" since it is inside the stove. Any special adhesive? I figure I might as well replace the gasket since I now have to take it apart.
Thanks!
Thanks!
