I'm troubleshooting a gas (propane) fireplace. The pilot won't stay lit (after I ignite it with piezo start and let it burn 30-60 secs. I pulled the unit out to have a better look, and then decided to try again to light the pilot - this time it worked.
Attached is a picture of the pilot assembly, from the manual, and a photo of a replacement unit for sale (the exact spec'd part#).
A few questions:
1. Why does this thing have a thermopile AND a thermocouple ? I thought they did the same thing: detect a lit pilot flame and allow a valve to continue providing gas to the pilot. The "thermopile" seems to connect with two wires, as I expect, as it provides a signal of some millivolts to enable gas flow. The "thermocouple" seems to connect with a small gas line of some kind. What's the deal here ?
2. Is intermittent failure common in a thermocouple/thermopile, or should I search for alternative causes of the intermittent failure ?
3. You can't see it too well in the photo, but the thermopile is semi-permanently connected to the bracket which also holds the igniter etc; rather than with a locknut securing it into a small hole (as seen in photos of typical units). Is it a mistake to try to just replace the thermopile ? (I'm sure I can do it without damaging things).
![question about gas fireplace pilot light question about gas fireplace pilot light](https://www.hearth.com/talk/data/attachments/302/302808-dfa111cd79a89b75e2fb310504415b75.jpg)
A few questions:
![question about gas fireplace pilot light question about gas fireplace pilot light](https://www.hearth.com/talk/data/attachments/302/302807-544f84234e54311100f70e38beac4b40.jpg)
