Im installing a wood stove thru an older brick chimney.
Im going to close up the older fireplace to only have a brickwall exposed to the room.
I plan to run a stainless flex liner inside the brick chimney.
I presently have a 6 inch round 304L liner ready to install it made by a company called Chim Cap.
I recently ran into a chimney guy and he said that this liner is not strong enough for wood and I need need this:
Sleepy Hollow upgraded SUPER FLEX® from type 304 to type 304-L late in 1983. This more expensive, less readily available alloy was chosen to provide greater protection in the event of repeated chimney fires—eliminating the hazard of intergranular corrosion. Removing the carbon content accomplishes three things:
1. Elimination of chromium carbides (carbon combining with chrome at high temperatures).
2. Less carbon increases the chrome and
nickel content, increasing corrosion resistance.
3. Reducing carbon content makes the
stainless slightly softer, enabling it to drill, cut, and form easier as evidenced by our unique oval chimney liner series.
Type 304-L stainless steel is a non-magnetic alloy with a carbon content of .03 maximum, chrome content 18/20, nickel content 8/12. Using mill certified stainless purchased from specialty mills ensures the highest quality stainless alloy available. Our SUPER FLEX® carbon content usually runs about .013 maximum, with small amounts of moly present, ingredients not found in grades of stainless used for many of today's chimney liner systems.
I noticed that the latter is much thicker and heavier.
Since Im getting opposing info Im confused.
Can anyone offer advice here?
