I’ve got a question for you guys. Over the summer I installed a new woodburning fireplace and it really puts out the heat. As expected, there is a part of the house that the heat doesn’t quite seem to reach, which leads to my question. In the photo I have attached, you can see the upstairs of my home. Currently, the door on the left is the only access to a room behind the wall that is approximately 17’ X 32’. That doesn’t allow for a lot of air movement. The part you can see around the ceiling fan is the hottest part of the house with the fireplace burning. What I am thinking of doing is towards the top of the ceiling, behind the ceiling fan towards the right, cutting out a small section of drywall on each side of the wall you can see, and installing a fan that will help move warmer air into the room you can’t see. I’ve read many posts about moving air and realize some believe it works and some don’t. I am thinking if I have the fan blow the cooler air out of the room you can’t see, into the warmer space you can see, that perhaps with the door open warm air will circulate into that room better? Or since the area where the fan will be located is so warm, would I be better pulling warm air into the room with the fan? Any idea’s or suggestions you guys can offer would be very much appreciated. I will also put links to the pictures below, each photo link also has a description of what I am after, Thank you...
http://i405.photobucket.com/albums/pp135/mtj54/upstairsphoto.jpg
http://i405.photobucket.com/albums/pp135/mtj54/upstairslayout.jpg
