j-takeman said:I would check the old igniter with a meter. If it has a dead short, It possible you also popped something on the control board. I really wish they would all start using a simple fuse to protest the boards!
marc4fishing said:just got back from the weekend in the berkshires. looks llike volts to ground (stove body) are 3 to 3.5 volts or so...everything else works though...looks like I have a manual stove from now on. Anyone know what the voltage should be?
marc4fishing said:the igniter is cold. the only fuse in see is the main fuse that takes out everything. where would i look for the igniter fuse?
