Hi, I had to remove the control board on our Mt Vernon AE insert to repair some bad connections. While removing the thermocouple cables, the plastic pin housings pulled off of the board. Now I am trying to put them back, but what the manual I have shows is exactly the opposite of what I'm seeing. There are two TC cables...one from the firepot and one from the drop tube. I have identified the firepot cable and marked it. The cables have slightly different plugs...the firepot plug has a locking tab on the side, while on the drop tube plug the locking tab is on the "face" of the plug (see photos). The pin housings which came off the board will only mate with their respective plug, i.e., they're not interchangeable.
The pin housings have tiny plastic alignment pins to line them up with respective holes in the board. The orientations of the holes are different, so each housing must go in a specific location. In the PCB photo, the lower connector only fits in the TC2 location. That lower connector only fits the plug for the firepot TC.
Here's the problem: the manual I have shows that the firepot TC is supposed to be connected at the TC1 spot. But the connector types are exactly the opposite.
Does anyone know which TC should be TC1 vs TC2?
Thanks.
![Quadrafire thermocouple connections incorrect in manual? Quadrafire thermocouple connections incorrect in manual?](https://www.hearth.com/talk/data/attachments/303/303913-4689803d20cda58bf70074c9f2de407e.jpg)
Thanks.
![Quadrafire thermocouple connections incorrect in manual? Quadrafire thermocouple connections incorrect in manual?](https://www.hearth.com/talk/data/attachments/303/303909-2037c00c802f41cfc60ccec19ec68778.jpg)
![Quadrafire thermocouple connections incorrect in manual? Quadrafire thermocouple connections incorrect in manual?](https://www.hearth.com/talk/data/attachments/303/303912-cd2df74f36c79d651911aa16173860c1.jpg)
