Greetings group lots of good info here long time lurker first time poster.
I thought I would post my mis adventures in rebuilding a 2003 Quadrafire SantaFe exhaust system.
There are several issues with the design of the Quadrafire SantaFe that I had to address:
Hope this helps someone else keeping one of these old stoves going.
![santafe_diagram-1.png santafe_diagram-1.png](https://www.hearth.com/talk/data/attachments/319/319056-3e4468e166fb4f0446fcb72cf4f25d62.jpg)
- The gap between the "exhaust transition assembly" #31 on the diagram (green arrow) and the "exhaust blower" is too big to fill with sealant and needs to be welded.
- The "exhaust transition assembly " does not extend far enough out the rear of the stove to make a proper transition to vent pipe (blue arrow). At first I thought mine just had been cut short but then comparing to the one on the diagram I concluded it needs to be extended.
- The diagram does not show the housing & stove gasket and the motor and housing gasket locations.
- The motor is attached to the housing with plain coarse thread sheet-metal screws , there is no way to re-do this and get a tight seal.
- Weld the "exhaust transition assembly" to the "exhaust blower".
- Weld a 3" pipe extension on the "exhaust transition assembly".
- Install 10-32 rivet nuts for the exhaust motor on the exhaust blower housing, so silicone replacement gasket can be tightened properly.
