this is a Santa Fe C, clear control box, no OAK. the stove shuts down on medium, thermostat is calling, thermocouple indicator light is green, auger is -not- running past initial feed.
the stove runs fine on low or high. on low, the light stays green, but the auger continues to run (and the stove operates as expected). on high, the light changes to red after a while.
when operated on high, to the point where the thermocouple indicator light changes to red, then toggling to medium, the stove will run for a couple hours, then the light turns green and the stove shuts down. on low, with the indicator green but the stove functioning normally, the igniter turns off - i can see when it's on, and the stove is only pulling about 100W.
i have cleaned out the stove to the extent possible without taking off the blowers (toothbrush, pipe cleaners, vacuum with flex tube attachment, etc.). not counting the blowers (which i admit to have never cleaned prior to the problem), cleaning routine was per manual - accessible burn chamber area every bag, baffles/heat exchanger/hopper. chimney flue and stove exhaust are clean.
if the stove is operating on medium and shuts down, resetting restarts the cycle.
this is a new problem at the start of this season - did not have this issue the prior two seasons. "mileage" on the stove is about 7 tons of pellets.
all parts are original. no modifications. i have re-seated the control box (stove unplugged), other than that, nothing intrusive. problem is stable/reproducible, no changes after cleaning blowers and re-seating control box.
i don't have a clamp meter sensitive enough to measure the thermocouple in operation.
would appreciate any suggestions.
