Hello everyone,
looking for some help on a Santa Fe Insert, we purchased this unit new in 2007 and ran it regularly but have not ran it the last 2-3 years. I have pulled the insert out, cleaned every possible nook and cranny on this stove, replaced the exhaust fan and also the vacuum switch, removed the auger assembly and cleaned the entire feed tube and the nipple where the vacuum line hooks up.. But I am still getting some type of vacuum leak as the Auger will not start during start up cycle, it works fine if I bypass it or create an external vacuum on the hose itself. I thought it maybe the door gasket, but I swapped doors from the other santa fe insert we have that is running with no issues and it still with not get enough vacuum to activate the switch.
