Quadrafire Santa Fe first startup of season failing
whit
207
Southern VT
I've looked at this thread: https://www.hearth.com/talk/threads/quadra-fire-just-flat-out-quit.167959/#post-2262348. I may need a new auger motor. For several years that motor has been weak on first run, requiring some prodding of the auger to get it going. This time it's not even trying to start. This is the older model Santa Fe free standing, bought in 2009 at about the end of its run. At present the heating element comes on, but no auger or fans. Can't remember if the fans should activate ahead of the auger on a cold start or not. The red light is constant. Can't recall if that's proper for this stage either. Have to dig out the old manual -- Quadrafire's site seems to only have the manual for the current model.
Would the next logical step be to pull the auger motor out and test it?
Nice to see this site's still here. Y'all have been a real help in the past. Thanks in advance for all advice.
Your combustion blower should run from the getgo. If it’s not running, your vacuum switch won’t close and it won’t feed. Also, which red light is on?
Reactions: kappel15
You're right. Thanks. I just went to start it again to see which red light it is coming on. This time the combustion blower started, then the auger. Last night in a number of tries there was nothing from the combustion blower at all. This is the proverbial car that won't act up for when taken to the mechanic.
Does this mean that the combustion blower is likely near end-of-life? Is it time I should order up a spare?
The red light is the call light. All the tells you is that the stove is calling for heat and should be running. If the combustion motor isn't coming on right away that's an issue. The comb. motor should be the first thing to come on. I would direct power the comb blower and see if it works. Or see if you can get the fan to spin freely with your hand, if its stiff or wont turn its seized up and you need a new one.
I've had comb. motors not start up cause they were getting old and stuck(dirty). I would reach back there and spin it by hand, and it would take off. kap
It's been running now for a week without further issue except sometimes a little noise. So that first night it may well have been stuck, either because dirty, or lubricant (if any) getting old, or just wearing out -- or all three. The noise suggests wear. It looks like if I go to replace it there are some third-party parts available. Are some of them notably better or worse?
Some have had issues with after market blowers. Make sure of specs before buying. Esp. rpms. But on the other hand, Quad has changed suppliers, and the holes don't line up perfect on their motors either. I know as I put a new exhaust motor on my Santa Fe last year, and did a lot of growling. kap
Do yourself a favor, get Quadrafire's motor, one less thing to question.
