Quadrafire Mount Vernon non AE troubles
Scolpe
1
Carlisle. Pa
I have a Quadrafire Mount Vernon non AE that I’m having yet another problem with. When I plug the power back in I get a blue light that flashes on the control box 4 times (I know this is the setting) but that all that happens. Nothing turns on except the red call light. I have by passed all snap discs, one at a time. I have jumped the thermostat and all remains the same. I have power but that’s all I can say. Any help would be appreciated.
Mount. Vernon Ae, 2006 or 2007
Working on my elderly dads, pellet stove. Truthfully, he hasn't cleaned this thing as much as he should have.
Somehow when he changed out the ignitor. He knocked out the control box. The power cord from the power supply to the control box was fused into the control box. I installed new control box and power cord, plugged unit back in. Ran through auto clean mode, and went into start up, no errors. Ran through start up, no start. Still no errors, it did feed pellets. Checked ignitor, getting warm, but not hot, digital thermometer said 495 degrees. Switched out ignitor with new, no change. No start.
Checked the connections on the supply and the control board. All seated. I pulled the power supply. Fuse was intact. But looked slightly burnt. I replaced fuse with 5 amp time delay 125 volt fuse. Put it back together. No change.
I lit the stove off manually. Started. No errors. Ran from start up to high. No errors. Been running since i lit it off. No errors.
Dad's on fixed budget. I just dont want to keep throwing parts at it. Kappel15, what am I missing?
Mount vernon ae control board.
Fyi, purchased a new control board for a mount vernon ae from clearview fireplace oswego ny. I called them directly. Sold me one for$499, had it in 2 days. Local dealer told mw $800 plus and 3 weeks
Reactions: kappel15
Not sure why you're hijacking the OPs original post?
