After 11 seasons and as near as I can figure 160 face cord of wood the Isle Royale needed to come apart. The front panel to side panel gaskets were leaking really good and the stove had to be disassembled.
First I removed the stovepipe and rear heatshield, the doors and top griddle as well as the baffle.
The top of the stove was removed next so the air manifolds could be accessed. Then using a small ball pein hammer and a 1/4" chisel I went to removing the cement on the front and side vertical manifolds as well as the cement around the bottom of all the main panels. The vertical front manifolds have at least a pint of cement at the bottom in the internal cavity and care must be taken in removing them.
Next all the flat head screws holding the manifolds in were removed. They were tight, corroded and stubborn. Just move work them back and forth patiently and they come out.
After the manifolds are removed the start up air on the back panel was removed. These small screws were the most difficult and my perfect record of no broken bolts or screws came to an end. I broke one off.
At this point remove the nuts and studs and you have a Quadrafire in pieces.
I used my 4 1/2" angle grinder with a twisted wire wheel to clean the grooves out and a cup wheel to do the rest.
![Quadrafire Isle Royale rebuild Quadrafire Isle Royale rebuild](https://www.hearth.com/talk/data/attachments/200/200568-47c358553ae19a14d8f96cb65d8346f3.jpg)
![Quadrafire Isle Royale rebuild Quadrafire Isle Royale rebuild](https://www.hearth.com/talk/data/attachments/200/200565-72a65e8e0283119aff26aecf4c365b8e.jpg)
![Quadrafire Isle Royale rebuild Quadrafire Isle Royale rebuild](https://www.hearth.com/talk/data/attachments/200/200566-cbff9833c23009bb0c47ff9cacbcebbc.jpg)
![Quadrafire Isle Royale rebuild Quadrafire Isle Royale rebuild](https://www.hearth.com/talk/data/attachments/200/200567-5d741c8a295f67058c66aae31337dff0.jpg)
