jburner said:What kind of stove do you have? Don't bypass the snap disk unless you unplug first. You can fry your snap disc. I've done it before. Whenever you try anything with the electronics side, always unplug first!
starling310 said:Hey everyone. I'm new here. What do you mean when you say "create a jumper?" or, "bypass" something?
tjnamtiw said:starling310 said:Hey everyone. I'm new here. What do you mean when you say "create a jumper?" or, "bypass" something?
It means that you should probably call the dealer or an electrician or, if you stick your hands in there, call 911. Sorry, but I'm giving a wise crack way of saying that you probably shouldn't be messing with it if you don't even know how to jump two terminals together.
starling310 said:Got my thermostat hooked up and running without any major incidents. So, thanks.![]()
I've done some electrical before...I think I was more confused by which terminals to use on the 5 wire thermostat I had vs. the 2 wire stove. But, I figured it out.
tjnamtiw said:starling310 said:Got my thermostat hooked up and running without any major incidents. So, thanks.![]()
No problem. You just scared me with your question about jumpers. As for the thermostat, did you use the W and Rh terminals?
starling310 said:I am naturally inclined to be scared of Electric work, so I tend to be extra cautious!
Yes, I used the W and Rh terminals with a jumper between the Rh and Rc terminals.
It's working like a charm.
