Hello all,
I have a Quadrafire Contour pellet stove with the old style control board. I am having an issue with it sensing fire in the fire pot from and is not feeding any more pellets from a cold start.
What happens is when the thermostat calls for heat the big red light comes on and starts feeding pellets. The igniter then lights the pellets and starts the fire. However the green light in the control board never comes on so the auger never feeds any more pellets after ignition. The odd thing is that if I hit the reset button one or two times to feed more pellets and get a real good fire going then the red light on the control box will come on and it will start it's normal operation, but the green light will stay off. The green light then comes on 5-10 minutes later and both lights stay lit during normal operation. This only happens when the stove is cold like when it first starts up in the morning.
The odd thing is that if it has enough voltage to turn the red light on, should it not also turn the green light on? I have tested the thermocouple inside and outside the stove with a lighter and I am getting voltage from it. What voltage should I be getting from it in order to turn the green light on? Could this be a thermocouple or control board issue? Any help would be appreciated, thank you.
