Hello
It seems that the Brand New 3 prong Electrical AC cord did fix false starts above freezing at normal operating temps.
See pic of new and old AC cords here
https://www.hearth.com/econtent/index.php/forums/viewthread/91793/
However the colder weather brought back the false starts. Now these false starts ONLY happen below freezing and in this test case it was 26 Deg F inside and outside the shed!!
Is this a real problem that many people would have, well maybe not.
So I will try to make it better but there maybe no guarentees here.
So what happens?
Not enough pellets are dumped into the burn pot below freezing to start the stove.
The hopper is full and the ignitor lights and warms the pot.
My pic shows the pellets did burn down.
Hitting reset does dump more pellets into the fire pot and then it does lite and run fine
Then the fire in the pot brings the stove and the room up to normal operating temps and it runs fine off the thermostat from then on.
Although it does take longer for the ignitor to warm the ductile iron fire pot below freezing, I do not think it is a big factor since there is not enough pellets in the pot for starting but I will see and be aware of this.
Note: This older feed motor does not use a capacitor.
See
https://www.hearth.com/econtent/index.php/forums/viewthread/91938/
So at 26 Deg F, I tried wiggling the molex connector to the feed motor and it did seem to help. The auger turned more but not quite enough.
So my next attempt for a remedy will be to get some Conductive Greese for all electrical connections that bring power to the Auger Motor. Since the motor does seem to operate fine, the weakest point that I can see is the spade connectors, the molex connector and even the new AC cord connected to the older stove male tabs.
Conductive greese is use more in colder climates like Alaska. Can anyone add to this?
Maybe a new main fuse would help?
![shade smirk >> >>](/talk/styles/default/xenforo/smileys/shade_smirk.gif)
So what happens?
See
