I have a quadrafire classic bay 1200 pellet stove that will only drop enough pellets to light small fire then it dies out before it begins to drop more. The feed shoot is open all the way but it still doesn't drop enough initially. Ifi hit the reset it drops more and the fire takes off without any problem. This usually happens when it first starts after being cold for sometime like in the morning. Is there an adjustment to cause more to drop at first???
The stove is totally cleaned and the feed shoot is also. Seal around door is new too, the problem was before and still after this was replaced. IT just doesn't drop enough... Frustrating![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
I found a clear control box in the hopper area under a metal box and it has a white dial like screw with a slot for a screwdriver in it on top. What Does this control???
Thanks much for any help! We use this to heat the whole house and is used as our only heat source...
Louie Kirk...
Louie Kirk...
