smwilliamson said:Quad ash bins are separated from the burn chamber to the sides of the burnpot....so it will not matter if you have a gasket or not unless you loose power...
ahhh yes... older mt vernons too if I'm correct.DexterDay said:smwilliamson said:Quad ash bins are separated from the burn chamber to the sides of the burnpot....so it will not matter if you have a gasket or not unless you loose power...
On the Mt. Vernon, Santa Fe, and Castille it wont matter. Its a burn pot with a flat top.
But the CB 1200 is the ONLY stove that Has a gasket on the ash pan and does matter. The sides are wide open and you can see the ash. The ash from the pot actually makes it way to the ash pan.
On all others. Its there just for the clean-out. Not the Classic Bay.
mralias said:WOWThat ash pan is huge
My CB1200i pan is 1/4 the size of that. Oh and no gasket. But it does have a ash pan door.
DexterDay said:Does that gasket go all the way around Don?
If it doesnt. Then you still need a gasket. It has to go all the way around.
The 1200 insert doesnt have open sides like the Freestanding unit. So its ash pan doesnt need a gasket.
The freestanders are open and need a gasket. Its not a flat gasket either. Its a 3/8" or 7/16" round gasket. Goes around the entire ash pan. Without it, your stove will have a Giant leak and not operate properly.
The motors may have changed on the auger. But the Main chassis of the stove is the exact same from its inception. The gaskets and everything are the same.
Just sayin
DexterDay said:Dont remember whether it was Stove Bright or High Temp BBQ paint.
Because it was the inside of the firebox and it gets burned off after the first few fires, I dont think it truly matters. It could be a standard black paint. Wont last long in that environment.
If I was to ever paint the outside, I think I would do like a Dark Brown, Burgundy, or maybe an Ivory White. Whatever color I chose, it would be a Stove Bright color.
As for the gasket. I dont think thats a factory gasket? Shouldnt be made of rubber. That and the manual states its a regular gasket (7/16" rope). Dont know how well that will work.
Sounds like that was some idea the Previous owners had?? But do what you want. As hot as that area gets, (exposed area of firebox, subjected to high temps) I personally wouldn't want rubber used. Unless I knew it was a High temp closed cell rubber.
Looking forward to pics...
