I have a Castile pellet stove that I bought in 2007. It ran great until I accidently pinched the blower motor wires after cleaning the fan. That fried the control board, bought a new one from Pellethead. After replacing the control board every once in a while it would not start up. The call light would come on, but nothing else started. You could hit the reset button or turn the thermostat off and back on and it would start up and run. It might run great for a week then do it again or it might do it once, twice or all day long and you have to start it every time. I've turned the control board to the diagnostic mode and everything checks out. I've replaced the thermostat (both manual and auto one), the thermo couple burned out replaced that, combustion motor was getting week replaced that, changed the vacuum switch. Also changed the connector for the control panel.
When I mean the stove doesn't start I mean the combustion blower, auger or ignitor come on. When it does start it will start in less than two minutes. Only the red call light comes on.
I suspect that the control board is the problem since it didn't start doing it until I replaced it. Looking for recommendations, don't want to change the control board right until fall.
Bob
Bob
and the green light comes on and it then feeds another cycle of pellets which in turn start burning and the fire pot temp rises to about 800
! POLARITY WAS SWITCHED ON THE THERMALCOUPLE!
