My door gasket needs to be replaced. Looking at door I can see what appears to be two gaskets. One that looks like it holds the glass in place. I am assuming that is the "tads pole" gasket I have heard about?
The other gasket at first glance looks like regular gasketing, but I see a metal rod on each side of the door. At first I thought the rods held the door gasket as I can see gasket material under the rod, but a second look has me thinking that the gasket under the rod is actually the "tad pole" gasket, and the rods do not need to be removed?
Any tips on replacing the door gasket?. I notice the factory gasket is slightly cut on the inside corners to get the gasket around the bends. Is this a standard gasket size, and do I glue it in place etc.?
PS I also nees gasket for the area behind the rear cast iron panels
