I had to get a new blower motor for my Quad Santa Fe (PN: 812-4400) because one of the two bearings on the shaft were starting to get loud. The fan is over 15 years old so I think it's done well. Anyways, I kept the old one because the only thing wrong with it is the bearing.
The bearing in question is 608S made by NMB. You can probably replace it with a 608-2RS and it will be fine. The ones on mine were actually a rubber shield with metal reinforced on the inside so you can pop them off and re-oil. Doing this made them spin a lot easier, but there's still too much side to side play so it still makes a sewing machine noise.
Not sure who makes good bearings besides FAG? I'd probably avoid buying the cheapest skateboard bearings you can find, or any of the really cheap 10 packs on amazon.
![QuadraFire 802-4400 Exhaust Fan Bearing QuadraFire 802-4400 Exhaust Fan Bearing](https://www.hearth.com/talk/data/attachments/286/286992-d4a45dbfce8c126e4c1d1aaed5e9f1d6.jpg)
![QuadraFire 802-4400 Exhaust Fan Bearing QuadraFire 802-4400 Exhaust Fan Bearing](https://www.hearth.com/talk/data/attachments/286/286991-a52d954983bf8720b8319dc6851f1e3e.jpg)
