We're closing in on purchasing a 7100. One of the intriguing features is the additional ports for additional zones/rooms to be added. Due to our 2 story vaulted ceiling where the 7100 is planned to be located, I have a strong suspicion that our other 1st floor rooms will need some additional ducting from the ports on the 7100 and, while we have the walls open (we're working on existing construction, not new) I want to do all the work we're going to have to do.
1. Does anyone have any experience with the output from those ports? The vendor-supplied kit has a 160cfm fan on it... that doesn't seem terribly robust but... maybe it just doesn't take that much?
2. Our installer has never had a request to send the ports to the same floor the unit it sitting on by going under the floor... has anyone tried this or tried/been denied due the max 3 elbow guidance from the vendor? (in other words I'm wondering if there's any limitation on going under the floor on the same level as the stove and having the heat enter the room via an existing floor vent? )
3. if #2 is not a problem, does tying in one of these ducts to an existing hvac floor vent violate the "don't tie the 7100 into a central hvac system"? What I mean is that I understand that guidance to mean "don't try and divert the entire output of the 7100 into your hvac system and substitute for an alternate heating source in that system". Is tying it to the end of an hvac duct a bad idea?
