Hi guys. New here and this is my first post. I really appreciate your support!
Just bought my first home with my wife and the house has a pellet stove - Quadra Fire Classic Bay 1200. Previous owners lived here 4 years and never used it, so it was sitting idle all that time. I read up on pellet stoves a bit, got the manual online, and got to cleaning the thing inside and out. All ash is cleaned completely as per the Quadra Fire cleaning procedure in the manual.
Anyway, loaded it up with pellets, and started it up as per the manual. The pellet stove starts, big flame will eventually appear, and heat is radiating out - so cool! However, about 15-20 minutes in, it stops feeding, and the flame eventually goes out. Call light is still on on the side. I try resetting it a few times, unplugging/plugging back in, but I can't get it to start up again until the next day.
The thermostat it's connected to is set to 90*F so I don't think that is the issue. Likewise the thermocouple is cleaned off, wire pushed in all the way, and it seems to be about in the right spot (extends about an inch into the pot).
Any ideas here? The snap disc #2 is working. Definitely enough pellets inside. When it first starts up, there is vaccuum it seems as the exhaust motor is running, and when I go outside there is hot exhaust coming out the pipe. Front door is tight and sealed. The door that opens/closes the pot to clean ash is closed.
I read online about a vaccuum switch. I found it, but kind of confused from there. There is a hose running from this switch to what looks like the feed motor? I tried blowing into the hose from the vacuum side and couldn't blow through it - not sure if that means its clogged or if that is just normal?
I really appreciate the help guys - worst case, can someone let me know about how much it would cost to call a professional and have them come out and diagnose/fix?
Edit: also wanted to add, I believe the previous sellers already replaced the feed motor, as I found an old used feed motor in the attic in a box labeled "still works" - maybe they had this issue, replaced the feed motor, and it didn't solve their issue?
-Al
PS: on a side note, I have a lesser question that I was trying to figure out before this issue came up. In 20 minutes (before the flame dies) the convection blower never turned on. Is that normal? I replaced the snap disc #1 and no luck. I tried plugging the convection fan wires into Snap Disc #2 to test, and it turns right on. Likewise, if I heat up the Snap Disc #1 with a lighter, it makes the convection motor turn on. I guess I assumed it would turn on pretty quick but maybe it takes a long time to heat up and turn on? Just wanted to make sure that was normal. Thanks again.
-Al
