I know that practically all the books for these stoves say that lubricating the motors are unnecessary however considering my model is from 2006 I'd imagine it can't hurt. I do recall Sidecarflip and others mentioning they lube theirs with 3-in-1/SAE20. I'd like to attempt this on my Santa Fe unit.
Looking at the exploded diagram I am unsure of what to lube and where exactly and if a replacement gasket will be needed.
Attached is a diagram below. Do I just remove the 4 screws holding the feed motor and lube inside this area? Is replacing the nylon bearing necessary or is it probably OK? Auger is working fine, but I bought this as a used unit so previous maintenance history is unknown.
