Quadra-Fire Santa Fe and Honeywell CT87K1004
mk23169
2
NY
I tried replacing my broken Lux thermostat today with this simple CT87K1004 and the pellet stove just clicks repeatedly when there is no call for heat. Are these two not compatible?
The stove works perfectly when I jump the R and W wires together manually.
Thanks!
Mike
Any 12 volt ac tstat will work with this stove. From the sounds of it, you may have a bad spot in the tstat wire. Try cutting some off each end and see how it does. And it could be a bad tstat too. Just cause it is new, doesn't mean it is good. kap
Reactions: SidecarFlip
I see you are still on this side of the dirt..... Nice to see you Kap...
Reactions: kappel15
I ended up getting another simple mechanical Lux and it works fine. I knew it wasn't the wires because when you jump them it worked fine.
My guess is the tsat was DOA as well!
Thanks
Reactions: kappel15
Been my experience, the fancier the T'stat is with a biomass stove, the more touch it is. I use a cheap 10 buck no frills t'stat and have for years. Digital, 2 AAA batteries, nothing fancy. It was less than 10 bucks.
Reactions: kappel15
You said a mouthfull there. Aren't they all made in China now and probably not a quality build anyway. I'm on my second basic digital, first one was indicating 7 degrees cold all the time. Went to the landfill. I figured for 10 buck, just get another. Second one agreed with the temp probe on my Fluke.
