Hello, I recently installed a new Quadra Fire Santa-Fe pellet stove insert and have had this intermittent problem since day one.
The stove will start and stop normally many times as per thermostat call for heat (Red Light On) and then intermittently fail to start with (Red Light On and No Pellets in Pot) I cycle the remote thermostat from Thermo to Off to On and back to Thermo and the stove starts right up and will continue starting normally many times until randomly fail as described. When running normal it seems the start/stop sequence is as it should be. Call for heat (Red Light)Pellets feed ignites (Green Light) heats up and turns to (Amber Light) and convection blower starts. Shutdown seems normal also. Call light Off, pellets Stop feeding, cools down Amber to Green, than Green Off and last convection blower Off. When it fails to start the Red call light is On and there are No Pellets( when I checked the pot there where maybe 2 unburned pellets which I attribute to slipping by the auger when stove off.) Cycle T Stat and stove immediately starts.
Thanks Ray.
Thanks Ray.
