Hello, my Quadra Fire Mt Vernon (pellet insert) shut down with a "convection blower jam" error code. I pulled out the blower assembly and it was fine. When I removed the control board I found the male & female end of the 3-wire convection blower wire harness burnt out. I attached 2 pictures. It seems like overkill to spend $600 on a new board when just a connector is bad. Has anyone had a similar issue and had any luck replacing the connector/harness? Or possibly soldering the wires from the blower directly to the board? Another connector on the board (marked Neutral Line) shows signs that it was heating up too. Picture attached. This 2-wire connector has identical harnesses on either end and plugs into the power unit. It still function but I prefer to replace this before it goes out altogether. Anyone have a problem with this connector?
![Quadra Fire Mt Vernon control board & convection blower jam Quadra Fire Mt Vernon control board & convection blower jam](https://www.hearth.com/talk/data/attachments/274/274335-626ae295a8318a256909046328dfed8f.jpg)
![Quadra Fire Mt Vernon control board & convection blower jam Quadra Fire Mt Vernon control board & convection blower jam](https://www.hearth.com/talk/data/attachments/274/274333-2ca7c6634ff8d79c3e05ef84548ebfef.jpg)
![Quadra Fire Mt Vernon control board & convection blower jam Quadra Fire Mt Vernon control board & convection blower jam](https://www.hearth.com/talk/data/attachments/274/274334-67b0ea18773b90773deba22e07aa1b9c.jpg)
