- Oct 23, 2006
- 48
Just cleaned stove and flex. chimney liner. It's clean throughout. Stove starts and runs fine. Pellet feed is fine.
Blower fans run perfectly on High setting. After about 20 minutes or so I turn the blower to Medium. Fans run OK. Then later on Low setting fans run for a while, THEN STOP. Feed slows, etc.
Then I turn the fan to Medium, no blowers. After about 5 minutes the Medium speed starts again. Back up to high fans OK. sounds like a heat sensor problem.
Dealer mentioned problem could be Snap Disc -- #2 possibly.
Ceramic thermo. is tight against wire in burn bot.
Anybody have experience with this problem?
Trying To Keep Warm
Trying To Keep Warm
