So here's my problem. Less than a week ago we changed the feed (Auger motor) on our Castile insert cause it was making a noise and was bad. Stove was completely clean at the time.
Stove worked perfect for 2 days then stop feeding pellets into the firepot.
Stove works if I manually put pellets in firepot but does because no pellets are feeding into it but everything else works like combustion blower and heat element. Also I can feel the auger turning if I touch it with side panel off. It turns then stops and I hit the reset button on the front by the blower setting switch.
We have tried everything in the manual and what we've found on this forum. I'll list below what we tried.
1. Blew compressed air through vacuum switch hose towards stove.
2. Empty hopper of pellets and vacuumed it out. Pulled auger motor off mount and wiggles it around to my sure nothing was jammed. Found no issue.
3. Checked snap disc 3 but figured if it tripped stove wouldn't have power ( am I right on this?)
4. Checked snap disc 2 but this is auto reset so it would be bad and if that's true wouldn't the auger motor not turn or my stove wouldn't have power (am I correct I on this?)
I can't think of anything else to try. Anyone have an idea?
Really appreciate any help.
Thanks![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks
