Hi-
Well I think my Quad's auger motor is toast. I say this because over the past week or so, I've noticed that upon start-up the auger motor makes a noise like it wants to turn (or whatever it does) but doesn't...I'm not sure how I would describe this; an electric grinding/buzzing sound...? Likewise, when it finally does start to go, after the initial start up cycle, the motor makes the same noise but eventually it starts feeding. That all changed tonight. Stove started up (did the electric grinding/buzz noise) and entered the startup cycle. After the startup cycle completed, the green light came on but it simply stopped feeding pellets. I pushed reset a few times - no dice (this has worked before). I unplugged the stove - same result; no pellets came out of the chute.
I don't think it's a jam as I stuck a flat-head screwdriver up the chute to loosen any lodged pellets, but nothing fell out (this trick has worked in the past).
Anyway, are there any good resources out there on replacing the auger motor and auger (if that should need to be replaced too)? Any suggestions where I can get a new motor?
Thanks!
Thanks!
So 6 yrs seems reasonably new enough to not be crapping out an auger motor. I guess it also depends on the history of power surges, how much 'pellet crunching' it's had to do, was it put together on a Friday at 4:55 PM at the factory, etc.
I have never emptied the stove completely at the end of the season, only taken as many pellets out as I could scoop out. How do I run the motor w/o turning on the stove or is that what you mean? Sorry guys, not much of an electric guy - I don't mind pulling stuff out of the stove though.
Saves potentially defibrillating your $$$$ control board, or yourself !
ha ha ha. At least that's my luck.
Certainly, with out "Quad wizards" like Kap and others on this forum, I'd be flying blind or would have crashed and burned many times by now....... But, I digress .
