So i just got a Cab50 quadra installed this past Wednesday and so far loving it!
I have the right air flow set up with fans that the stove is able to heat the whole house on a high setting but im trying to find a way to run both my furnace and stove so that I can offset the cost... right now my pellet stove is burning more or less 5lbs an hour on high setting (running off of a Tstat) but doing so at that rate im burning around the same cost of wood vs the cost of oil. (also doesnt help were in a bit of a cold snap)
for those of you who have and run both a furnace and pellet do you just set and forget both T stats set at the same temp?
my stove T stat is next to the pellet stove (away from direct heat) and will typically call for heat much sooner then the furnace T stat that's upstairs.
I know it will take some time to tweak and find that "happy" setting but curious on what others have done to run both to work together vs working against each other (having 1 or the other go on and heat the house before the other can have time to start heating)
