I'm thinking about upgrading my primary pellet stove and using my Englander as a basement heater. I've narrowed it down to either the Quad Classic Bay 1200 ($2300) or the Harmon P-43 ($2500).
The Classic Bay is rated for up to 2,350 sq ft while the P43 is rated for 1,400. The CB also has a higher BTU output at 17,200-47,300 vs the P43 at 7,000 to 38,000(or 43,000 in Turbo mode).
I'm trying to figure out how much I should put into these numbers...as I know that the style, layout, insulation and so on of the house is really going to determine how much heat I can keep in.
Anyone have either of these stoves and can give me some feedback. What do you like or not like about each of the stoves? One of the aspects that appeal to me is that each of these stoves will require less day to day maintenance then my Englander does. I love the Englander, but I'd like something that requires a little less maintenance day to day.
What do you guys think?
The thermo probe I have attached near the inside air intake on the stove and it seems to work fine. Leaving the stove on room temp aprox 68 degrees (it controls the feed rate) it keeps the downstairs 71 and the upstairs 68-69. Cleaning is easy, not many parts on the harman, which is a big help. Simple design simple to use.
