Does anyone actually clean off the baffles? I'm not talking about vaccuuming out behind them, I mean actually cleaning the soot off of the panels. Ours are quite ashy and I'd like to clean them off, but am skeptical of doing so.
Usually about once a week, I will do a good cleaning of the inside of the unit. This includes lifting the baffles off and cleaning them in the kitchen sink. A little warm water and a scrub pad does the trick. I then let them sit to dry while I clean the rest of the stove out. I also have a brush attachment that came with the vac that I use to brush off what is left on the heat exchange tubes after using the cleaning rods. Also use the brush to loosen and vacuum some of the ash that builds up on the side walls. When done with the inside, the baffles are dry and they can be re-installed.
