Gang,
I needs some help here and would appreciate some advice. My 2010 4300 seemed to be overfiring and I found that the door gasket was leaking in several spots. i went to the dealer and pick up what they said was the proper replacement gasket (3/4) which is also what is mentioned in the Quad instruction manual. however, this gasket is decidedly elliptical. My questions:
1. Does the "flat" side of the gasket go into the gasket channel, or does the "round" side do into the channel?
2. Should I use RTV or furnace cement?
3. Should I place the door back on the stove and close the latch to ensure proper seating and gasket depth all around while the adhesive is wet?
Given the big cold snap coming, I need to get this done today. Thanks for your help.
