My PDVC also dropped air output, and looking at the blower, it is dirty- has anybody come up with an easy way to clean it, without pulling the blower? I don't want to pull the stove, and can't work on it with me upside down. Neck issues. Had some luck using a vacuum on blow, blew a bunch of crap out into the room. Works better, but still dirty, though.
Also, have a question for you all- what do you think happens to the current draw when a fan is starved for air? You know, when you hold your hand over the vac hose and it sounds like it will explode, the motor revs up like it is working REAL hard, right? One of the more interesting things is that the speed rises, causing the louder sound, but the CURRENT DROPS! The fan(blower) is using less energy because it is not doing any work- it is moving the same air around in a circle, so all the air is moving very, very quickly, and the motor is not doing any work. Well, when you blow out or clean a blower, and it starts to do more work, because it is moving tons of air now, it actually uses more electrricity and draws more current, so very often cleaning a fan/blower will cause it to fail rather quickly. Is this room air blower a Grainger item? How about the combustion fan? (Mine is noisy until hot)
