So in the interest of aesthetics my remodeling contractor put a shroud over collinear termination cap. This was my suggestion, though as client feasibility isn't really my department. The shroud has open sides and closed roof kind of like embedded photo (representative, not the real one). Now the fireplace company says (and they make sense) this is a terrible idea because it will impede good supply air flow because exhaust gases are no more likely to return via supply. Second consideration is whether heat dissipation is impeded in a dangerous way with this in place. Third could be warranty issues.
The proposed remedy: cut a rectangular opening (6"x8") right across the top ridge of the shroud to allow better venting. This will not be visible from the ground, so while I'm kind of up in arms about damaging something I paid hundreds of dollars for, I can see that it will work. My thought is OK, if you're going to cut holes in it, at least leave the ridge intact and cut two smaller rectangles (3"x8") to either side of the ridge and still very near the top. I don't know if that ridge has any structural importance and even if it doesn't it just seems better to leave intact.
Any input as to whether it's truly necessary or other solves? Thx
![Putting a shroud over gas termination cap - bad idea? Putting a shroud over gas termination cap - bad idea?](https://www.hearth.com/talk/data/attachments/183/183189-2e78d78373dd0985fec010dc82a1d67a.jpg)
