Man I'd split that and stack it. Only way that punk would affect anything is if that wood was rained on in cold weather and you wanted to burn it soon after, otherwise, if you keep it dry, I wouldn't worry about it.
No problem with that at all, just keep it dry till you burn it. And do watch out for the piece of metal that is somewhere in or near the piece in the first picture.
Actually that wood looks pretty primo to me. Youve got some really dense tight growth rings. Heavy shade forest conditions and slow growth wood. Good chit. ;-)
I don't think it's going to hurt anything, but wonder if burning a lot of the micro-organisms would mask the cat, necessitating a vinegar/water simmer sooner than if you were burning clean wood. No big deal either way, and you don't have a cat stove so no problem. When it's powdery-dry like in your second pic, there's probably not many critters left. I'm working on some Red right now that has varying degrees of punk. If it's pretty solid I won't mess with it. If it's softer, I might buzz it down with the small saw with a fairly dull chain or whack some of it down with a hatchet. Huge waste of time, more than likely.
As BD mentioned already, the sapwood in oaks (especially white oak) will get punky and soft if left in the weather. Most standing dead oaks I cut on the farm have the exact same thing......completely normal and expected. That stuff will be fine, get it stacked and top-covered if you wish. That is some primo wood!
I will be in Detroit next weekend for the Jimmy Buffet/Jackson Browne show. Split it and I will pick it up as that cannot be burned south of Clare.
Now I will be honest that will not hurt a thing. I have burned hundreds of cords of stuff like that and a lot worse.
I must have 13-14 cord of Red,Black,White & Bur Oak in varying degrees of that condition.....About 50/50 split between standing snags & deadfall. Keep it covered & it'll last for years.
Curiosity, made me check MC on said Punk, that has been uncovered ,surprise, 18%, a few dry days and it looses moisture fast, I assume cuz it is so, less dense
If the bark is loose or coming off, just know it all the way off. Yu ain't losing much BTU's knocking the bark off. and it will dry faster.
Same with stacking, more air exposure= faster drying.
