Pulling out Jotul 550c to install block-off plate
JJEGLBS
35
Illinois
We have a Jotul 550c insert, which was installed last year. We love it, but I am thinking we're letting too much heat go up the chimney since no block-off plate was installed. So, I plan on removing the bad boy this weekend (with help, of course) and installing a block-off plate. Thanks to this group, I think I have everything set to do the job. The one thing I am uncertain with is removing the insert. How do I protect the brick hearth when doing this? I was thinking maybe a piece of carpet or sheet metal on top. I plan to put the insert on a movers dolly so I can get it out of the way to work on the block-off plate.
Also, before I disconnect the liner, would it help to make a cardboard template so that I will know exactly where the liner comes down in order to place the hole exactly right on the block-off plate (will the liner mover much after I disconnect)?
Here is a picture of the set-up, if it helps (notice the cardboard box to the left -- Koawool ready to place on top of the block-off plate)
[Hearth.com] Pulling out Jotul 550c to install block-off plate
Thanks.
We use a piece of aluminum sheet for insert install/removals...
Make it long enuff to cover the full depth of the hearth, wider than
the insert & long enuff to cover the facing of the hearth riser.
Bend it down where the hearth drops to the floor.
It will give you a spot to put your feet against it to keep it in
position when you slide the insert out & protect the front edge, as well...
We set em on a furniture dolly - with casters - to move em around after
they're out of the firebox.
When you're ready to install, the aluminum will, again, protect the front
edges of the brick & the bend will keep it from sliding into the firebox with the insert...
Good idea making the template BEFORE you pull the insert.
Great information. Thanks Daksy.
