So on Friday I will be installing my Ravelli RV80 can not wait to burn some pellets. Tired of hearing the heat pump run. Hopefully it will be dialed in as we are gonna get our first cold snap of the season.
Brand newcongrats on a great stove, did you buy it new or used
Stoves and stuff in Allentown. They are doing the install and going to walk me through set-up and general maintenance and cleaningif you don't mind where did you buy it, just wondering because I'm not that far from you, bought my Francesca from Kingdom Biofuels. did the dealer give you instructions how to setup the RDS.
They were very good to work with. Are parts hard to get have you had any major problems with the ravelli?Oh ok good deal, several folks here that are pretty sharp with the Ravelli's in case you have any questions. How was Stoves N Stuff to deal with, just wondering in case I ever need parts they may be another source.
We liked the design and they had the one in the showroom running and it was quiet. I was having trouble deciding between the 80 and 100 but thought the 100 would be overkill. I’m heating 1022 square feet open concept ranch with ceiling fans in every room. The price was great also compared to the Harman allure.Parts aren't a problem to get if going through a dealer but hard to get online, most other brands of stoves parts are easily available online. I haven't had a single problem with my Francesca to date, this is my 3rd season with it. Ravelli does use good components in their stoves so should be trouble free for several years. What made you decide on the Ravelli.
I figured once the house is up to temp I should be able to set it and let it run. Have you found a decent brand of pellets that burn best in the ravelli.yeah I love how quiet my Francesca is, I'm heating a 1275 sq. ft. open ranch with my little francesca and very very rarely turn my stove above heat level 1 so you should have plenty of stove with the 80. I ended up with the Ravelli because of a killer deal on it.
How long have you had the stove, how many pellets have been burned, when was the stove cleaned last.
Have you done a deep clean, opened the clean outs and vacuum, brushed the heat exchanger tubes, clean the venting.
How big a room are you trying to heat?
How well is the house insulated?
Are your windows drafty?
My guess is that the BTU output of this stove is inadequate for the size and insulation of your home.
You should do a "deep clean" after every ton burnt.
If and when the room temperature comes up to a comfortable level, back the power level to 4. And set your thermostat to a reasonable setting.....not 82F....
My wife considers 82 reasonable![]()
