We have a new-to-us Englander 25-PDVC pellet stove and we're looking for a thermostat. The manual says it uses a PU-DTSTAT but I haven't been able to find any in Canada, is there an alternative thermostat that would work with our stove?
Cal-rod?Which equates in my book to the cheapest one you can buy that is digital. I just bought a Honeywell non programmable millivolt digital for 18 bucks at Lowes. If you have 'cal rod' ignition you could go programable or even WiFi. Mine isn't (cal rod ignition). Mine is old school gelled firestarter or hand sanatizer, whichever is cheaper.
I just call it by it's correct name, not ignitor. All Cal Rods.Cal-rod is a type of auto ignition that sits under the burn pot
Calrod is a GE registered trademark for their tubular heaters. Lots of other companies make tubular heaters. And it is Calrod, one word.Just speaking in layman’s terms sir![]()
That all depends on where you live at. So tell me, how do you pronounce Detroit? Bet you never knew the correct pronunciation was 'Datwah' .Calrod is a GE registered trademark for their tubular heaters. Lots of other companies make tubular heaters. And it is Calrod, one word.
Hi Sam,totally off topic....
Btw, cool avatar maraakate!
Might I ask what tangential turntable is that? I'm assuming track selectable with remote?
I have an old luxman that I can play, cue and stop, but not select tracks via a remote control (or voice, since I got a remote hub that links to google/alexa).
It does not have a programmable range, as I opted to get the simplest heat only non programmable kind from a well known brand with tons of reviews for reference.Does your stat have a programmable range for the temperature differential? Mine doesn't so if I set it to say 75F and it drops to 74F it will cycle on again. Ideally, I'd like to have it drop 2 or 3 degrees F before kicking on again. I know there's some millivolt stats out there that have this ability, but haven't done research on which ones have the best cost-reliability ratio.
Ah, I see. I used to use a 'video disc' removed from it's case as a platform to dial in the anti-skate with an old stylus.Hi Sam,
It's actually a prototype LaserDisc, back when they were still calling it 'Selectavision'. I collect LDs as one of my hobbies. I like turntables as well... have a 1962 Empire 298 with a Denon DL-110 running into a 1965 HH Scott LK60. I have no experience (repair or usage) with tangential turntables. If you haven't been on audiokarma forums yet, check them out as someone over there might be able to help you fix it.
