Proper way to vent through concrete wall?
jdew1920
52
Michigan
Putting in a wood furnace right now. I will be using an existing clay linered chimney (7" square). There is an 8" hole already in place in the concrete foundation wall - I just need to drill a hole through the clay liner to access the chimney. The stove pipe will be 6". I was just planning on running single wall stove pipe through the existing hole to reach the chimney and just cement it in to seal it. Is this the way to do it or is there a better way? Most of what I see on going through walls deals with going through framed walls - just wondering if I was missing something on going through a concrete wall.
Thanks for any advice and have a happy Thanksgiving.
Think you should be alright. If I am reading you right, you may want to slid in a 6" clay liner to mate up with the chimney and then slide in the pipe.
Chad
Sounds fine, but I wouldn't cement it.... In case you need to remove the pipe, or anything else.... I'd just get some insulation and plug the gaps.... Stove pipe safe insulation of course!!!!
Not sure how much workin' room you have for cutting that hole in your clay liner, could be tricky.....ya don't want to crack the thing. How you plannin' on doing that anyway?
I just had a nice outside brick chimney built about 2 years ago, and I watched 'em do it. They cut the clay liner with a masonry blade, and after the clay liner was set, the clay "through the wall" thimble was mortered on the end and shoved into the cutout hole of the liner.
sounds like all you need is a hilti core drill
