I am installing a Harman PF100 in my basement. The exhaust piping is 4" ICC double thickness pellet pipe. My goal is to vent it to my chimney flue. There is an existing 5" circular access cut through 16" of cinderblock to the flue (from an oil hot water heater that used to be there).
Question: what's the best way to get my 4" pipe into that 5" hole? Also, how far into the cinder block should I run the pellet pipe? Should the pipe end with an upward facing elbow into the chimney or does it not matter? On the flipside, could I run the pipe, say, 6" into the cinder block and call it good as long as the pipe-to-cinderblock interface is airtight? I'd like to leave the flue unobstructed so I can sweep it easily from the cleanout at the bottom.
Thanks very much, guys.
Dave
Dave
