Hi all, I have an issue and I need help in the proper repair of my chimney,. I attempted to replace the cap or crown of my chimney which was crumbling due to age. Upon disassembly I noticed my liner was cracked at least 3 feet down. In addition to this there is alot of staining on the brick going further down than the crack is visible so I'm guessing I have some other issues with the liner. The liner is 12x12 clay and I have decided to just pull in a new stainless round liner instead of try to just replace the upper section of clay liner when there may be failure points further down the system. My problem is I do not know how to connect the flexable liner to my stove. I am not very knowledgeable but I am extremely handy. You can see going through the wall from my stove into my chimney is simply a 24" section of triple wall stove pipe. We have been using this chimney and wood stove for 10 years with out issue. Can some one please advise me on how to properly connect the 6" flexable liner to my pipe in the wall. I understand the correct way would be to use a tee but I do not know how I would be able to attach the tee to my pipe either. I had a local chimney repair guy recommend I just clamp the flue liner to my existing pipe but that does not seem correct either. Please advise.
