How did you get it off the pallet jack into your house?
With the jack slightly raised, I just pushed it until one side rested on the hearth. The crate did slide well on the pallet jack since there is such little surface area and the metal is smooth. Then, I blocked under the crate where it met the jack. Lower the jack and remove.
The hard part was getting it on the jack, since the crate does not fit a standard pallet jack. I had to use one fork and raise it a bit at a time and block until I could fit the low part (runners) right on the forks. It wasn't that bad.
Just keep in mind, the stove is over 700 lbs, think leverage, and take your time. I strongly suggest at least one helper.[/quote
So that wasn't the best description. I loaded it onto the pallet jack in the back of the pick up, rolled it down 2x10s into the house, then did what I described above. Good luck!
